SM wheel weight bolts
Posted by markloff on July 10, 2007 at 14:12:04 from (204.221.56.156):
Hello,
I want to hang 4 wheel weights on each wheel of my SM. I was told I need square headed bolts of the SAME length to do this. I seem to think I need long bolts for the first set to go on the wheel, then shorter bolts to hang the rest of the weights to each other. What is the easiest way to do this. Fastenal has square headed bolts that I need. Anybody got a better source?
Thanks in advance,
Mark
