Re: Whats your favorite gasket sealer?,why?
Posted by the Unforgiven on July 11, 2007 at 15:47:59 from (66.146.249.116):
In Reply to: Re: Whats your favorite gasket sealer?,why? posted by russ hamm on July 11, 2007 at 10:48:07:
Hey Russ, I've got some pretty good pitting between the middle ports on an F30 manifold, and I am a little apprehensive about milling it since the governor linkage is all cast and fairly rigid mounted, I do want to bind it up real bad, and it looks like it will take at least .040 to clean it up much. Have you used anything that will fill some gap and not burn out?
