Re: Whats your favorite gasket sealer?,why?
Posted by Hobo,NC on July 11, 2007 at 19:01:34 from (71.29.34.207):
In Reply to: Whats your favorite gasket sealer?,why? posted by BIG RED 1 on July 11, 2007 at 07:13:32:
Body of Message:
That's a loaded question and know one answer will cover all gaskets, when I started out in the trade mechanics in the shop used aluminum paint or enny paint, permatex sealers of the paste and liquid type and 3M 8001 glue. It still to this day grips my arse to see some one use grease on a gasket I spec cuzz I wuz the one that had to do the warranty werk to replace it after it failed cuzz the grease made the gasket separate. NO GREASE ON CORKE UBDERSTAND.
RTV gasket sealers have their place, their are different types of RTV sealeras for different oils/grease/heat ranges sum good sum not. Pushed into a corner I would say the gray RTV suits most needs, or I would fight ya if you had a thought of take'n it away from me. hers a little run down on my experience
Everyone will have hiz preference and its what werks fer them. Once upon a time we only had liquid sealers and they werked and still werk. Then came paste type sealers and they werk and still werk, then specialized sealers and they werk and still werk. I have all types in the shop and they all have one thing in common they must have a clean surface to bond to. I like the gray or black silicon for most applications. The blue izz still around but old technology and it never did like oil and the clear did not either. One thing to consider izz does the gasket have enny thing to do with clearance as to how the part fits if so then a gasket izz needed to set the clearance. A oil pump cover needs the correct gasket to set the clearance so use a gasket. If no gasket izz required then the use of a sealer izz up to the installer.. Day to day I install, water pumps if they use a gasket I glue it to the pump with 3M 8001 yeller gorilla snot, and smear a lite coat of gray silicon to the face of the gasket that meets the block for insurance and iffin I replace the pump the gasket will not stick to the block . Sum pumps used today on newer cars don’t have a gasket and use silicon. If in a jam I would use silicon on a water pump if no gasket wuz on hand. If the pump cover were pitted I would use silicon to fill in the imperfections. On cork I only put sealer on the joints enny sealer added to the cork will make it slicker than snot on a door knob and cause the cork to squeezes out and break. Only glue cork to one surface (3M 8001) and seal the joints. If the cork does not seal of I don’t feel it will or I don’t want to take a chance I use gray silicon and no gasket. Everyone izz rite on what they told ya it werks fer them so you will have to try it. I have to warranty what I do so use what werks fer me and still git bit from time to time. there are 5 sealants that hang around my werk table all the time, #1) Permatex 599BR grey silicon, #2) Permatex High temp silicon, #3)Mopar AXLE -RTV, #4) Loctite 515 gasket eliminator (don’t use it much enny more) #5) Permatex aviation form a gasket, mite as well add copper coat that I use to use and now got back to use’in on some head gaskets. Sum brake clean to clean the surface a good razor blade in a tool holder to scrape with will git’er’ done. Clean bright and thigh applies her also.
