Re: Seed plate seal (located on inside of left final drive)
Posted by georgeky on July 11, 2007 at 22:14:22 from (152.163.100.197):
In Reply to: Seed plate seal (located on inside of left final drive) posted by Patrick Martin on July 11, 2007 at 21:21:49:
Patrick, that same guy you was getting the overhaul kit from has them as well. Nearly every part for these tractors are still available. If it was a Case it may be a different matter, but Farmall parts are availble for most part. That should be available at good auto stores if you can match it up. Since you have the number that should be no problem. Call Brad he will send it right to you.
