Re: Carb Cleaning
Posted by Andy Motteberg on July 12, 2007 at 10:45:08 from (4.143.220.132):
In Reply to: Carb Cleaning posted by David Goode on July 12, 2007 at 09:52:10:
I've never bead blasted a carb, but I've seen bead blasted carburetors and they look like new. You shoukld soak the carb and parts for a while, they clean them off and dry and bead blast the carb body.
