Re: Cub/CubLoBoy? Clutch grind oil drip
Posted by billde on July 12, 2007 at 10:55:51 from (72.26.87.225):
In Reply to: Cub/CubLoBoy? Clutch grind oil drip posted by NawlensGator on July 12, 2007 at 10:30:12:
Engine would be the same but the clutch would be different between a Cub and a 154 loboy. Rear main seal should be the same.
