Re: Cub/CubLoBoy? Clutch grind oil drip
Posted by NawlensGator on July 12, 2007 at 12:58:01 from (52.128.30.25):
In Reply to: Cub/CubLoBoy? Clutch grind oil drip posted by NawlensGator on July 12, 2007 at 10:30:12:
Allright. I'm learning. Somebody put a newer cub engine in an offset loboy frame and messed up the clutch and the front transmission seal.
So which is a better mower for the bucks:
Offset loyboy (bad throwout bear and front xmission seal) with 42" belley mower for 18 big ones, or a nice 140 with a 4' woods rear mower for 7 more (maybe less)?
