Re: Carb Cleaning
Posted by Farmall MD on July 12, 2007 at 14:56:17 from (205.188.116.73):
In Reply to: Carb Cleaning posted by David Goode on July 12, 2007 at 09:52:10:
David, Glass beading is fine, I've been doing it for years. Anything larger will tend to jam up orifices like Janicholson said. If there is any brass or intricate pieces, try not to blast them directly. When you are done blasting, blow it out EXTREMELY well. Then go in with wire or torch tip cleaners to make sure all passages are clear. Then blow it out again. You can even atomize it with thinner if you want. Then get it primered right of way or you'll watch it rust before your eyes. Doug N
