Re: Carb Cleaning
Posted by CGtractor on July 12, 2007 at 16:48:23 from (69.50.45.236):
In Reply to: Carb Cleaning posted by David Goode on July 12, 2007 at 09:52:10:
I have bead blasted a number of carbs inside and out. These were all cast iron carbs. Clean all orifices when done and blow out with compressed air. Paint it soon after you get it reassembled to prevent rust. It works for me.
