Re: Super C PTO Interchange
Posted by gene bender on July 13, 2007 at 02:45:53 from (67.55.226.214):
In Reply to: Super C PTO Interchange posted by Wayne Mo on July 12, 2007 at 20:36:59:
Dont bet on the swap as there were two types of couplers that enguages the pto and therefore the main shaft in the tranny will either have an inverted spline or it could have the two bladed output. You wont know intil you have removed them. The tubes should interchange but check all the stuff before re-assembling.
