Re: Changing 6 volt generator from ccw to cw rotation
Posted by Bob M on July 13, 2007 at 04:56:55 from (151.190.254.108):
In Reply to: Changing 6 volt generator from ccw to cw rotation posted by 666farmall on July 13, 2007 at 04:00:11:
Not to worry! Simply repolarize the generator once you've got it installed and wired back up on the tractor and you'll be all set.
(Generator field widings are not rotation sensitive. Rather field polarization, and the polarity of power applied to a generator will determine the direction of armature rotation when "motoring" a generator on the bench.)
