Re: Sandblasting or grinder brush?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Chevy on February 10, 2000 at 05:54:11 from (207.139.197.210):
In Reply to: Sandblasting or grinder brush? posted by Jon on February 09, 2000 at 15:37:50:
Jon
Blasting is the way to go, rust is a fungus and the only way to get rid of it is blast it off, a wire wheel will work but not as well and you'll spend hours doing it.You can blast pretty well everything but be real careful with the hood unless it's really rigid, I blasted a Massey 30 hood and watched it curl into a tube shape.The fenders and gas tank will take the high pressure blasting but cut the pressure on the lighter tin.The other nice thing about blasting is you can blast,epoxy & paint all in one day.Anyway, good luck whichever route you choose.
Mike Leggett
Post A Followup
: Re: Re: Sandblasting or grinder brush?
