Re: H front wheel bearings
Posted by Janicholson on July 13, 2007 at 08:41:48 from (199.17.6.122):
In Reply to: H front wheel bearings posted by Alan Martinson on July 12, 2007 at 21:31:46:
Have the hub machined on that surface for the next larger size OD bearing cup in that sequence (might be metric) of machine out the bore an eight, and machine a press fit sleeve into the hub, then machine it to original spec. JimN
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
