Re: Transporting tractor
Posted by MN Mike on July 13, 2007 at 11:13:09 from (216.77.154.39):
In Reply to: Transporting tractor posted by Kevin H on July 13, 2007 at 11:00:47:
usually the biggest hurdle to bringing home a non-running tractor is the wife :)
Most 1/2 ton trucks should be able to handle the weight if you have a good trailer with brakes. Chain it down with load binders and you should be fine. I think an M runs around 5-6000 pounds. Others will correct me if I'm wrong.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
