Re: Taking radiator off an H
Posted by Red48M on July 13, 2007 at 16:14:45 from (199.2.124.63):
In Reply to: Taking radiator off an H posted by Dalton S. on July 13, 2007 at 15:46:45:
You need to take the steering shaft out. You do this by disconnecting the shaft at the U joint, then removing the plug on the front of the bolster. Then turn the shaft and worm gear out. The radiator is held in place by two bolts that you get to from the bottom of the tractor.
