Re: Transporting tractor
Posted by old on July 13, 2007 at 17:31:17 from (4.244.57.74):
In Reply to: Re: Transporting tractor posted by Kevin H on July 13, 2007 at 15:35:00:
One way you can do that is. Pull all the plugs out. Then stick a 12 volt battery in it. Put it in first gear and hit the starter button. Don't hold it for more then a minute at a time. It will crawl right up if you do that and not hurt a thing. I have loaded 10 plus tractor that way and even a crawler or 2 doing that. If the brakes work thats a plus. If they don't if you have help have them throw a block under the rear tires to hold when you have to let off of the start just to make sure it doesn't try to roll back on you
