Re: Loud , hard starting SM
Posted by glennster on July 13, 2007 at 19:08:02 from (68.60.242.156):
In Reply to: Loud , hard starting SM posted by Keith L on July 13, 2007 at 18:36:06:
run a compression test on all cylinders. then add a couple squirts of oil to each cylinder and re run test. if the reading are low and dont come up, suspect valve problems. could be they just need adjusting, but the oil burning cylinder may have a worn guide or bad seal. pull the valve cover and inspect the valve train too.
