Re: Transporting tractor
Posted by NDS on July 14, 2007 at 08:11:42 from (64.12.116.73):
In Reply to: Transporting tractor posted by Kevin H on July 13, 2007 at 11:00:47:
Another consideration that I have not seen mentioned is that if you have late model 1 ton truck with a GVWR of 12,000 lbs+ and a trailer with a GVWR of 14,000 lbs+ you are in CDL class. It does not matter what truck and trailer actually weighs they will go by combined GVWR ratings and if you are checked and do not have Class A CDL you will be put out of service on the spot and someone with proper license will have to move truck. Ther are some exemptions for farm plated vehicles and if you can prove that you are not engaged in any type commercial activity.
Class A CDL..Any combination of vehicles with a GVWR of 26,001 lbs or more provide the GVWR of the vehicle(s) being towed is in excess of 10,000 lbs.
