Re: H only runs choked full
Posted by Andy Motteberg on July 14, 2007 at 09:28:42 from (4.143.216.249):
In Reply to: H only runs choked full posted by KennyK on July 14, 2007 at 08:41:33:
Sounds like you need to do some carb work. Remove the carb and parts and clean in carb cleaner, bead blast carb and install a new kit and adjust the carb correctly. Also make sure the fuel filter, fuel line, sediment bowl, air cleaner and fuel tank are clean.
