Re: H only runs choked full
Posted by old on July 14, 2007 at 12:05:23 from (4.244.217.123):
In Reply to: H only runs choked full posted by KennyK on July 14, 2007 at 08:41:33:
Sounds like a clogged up carb/main jet. One thingyou can try is remove the drain plug out of the bottom of the carb and let some gas flow out for say 2-3 minutes. Then turn off the gas and remove the main jet adjustment screw and spray carb cleaner into the main jet, leave the drain plug out so the cleaner will flow out the bottom. If that works your good to go if not you will need to rebuild the carb
