Re: Sweep Bolt
Posted by SuperA-Tx on July 15, 2007 at 09:05:53 from (4.227.108.28):
In Reply to: Re: Sweep Bolt posted by gene bender on July 15, 2007 at 02:43:35:
Gene,
Carriage bolts will "work" but on the Spring Tooth Cultivator sweeps they are counter sunk and the carriage bolt doesnt fit right. Hex and square heads work too but just not correctly.
I would have used the carriage bolt but you cant find 7/16 ones here so I have to order them anyway. So I figured I might as well get the correct ones if Im going to that much trouble.
On my Texas Sweeps on the 144 cultivator I do use the carriage bolts. They are the correct ones for that.
