Re: Super C won't start?
Posted by El Toro on July 15, 2007 at 11:51:27 from (64.12.116.73):
In Reply to: Re: Super C won't start? posted by Dan( Mass) on July 15, 2007 at 04:06:17:
third party image
Here's a picture of a mag and No1 plug wire is around 1 o'clock. You can see the plug wires going to plugs in the correct firing order. Don't get shook up about an ignition coil in the picture. The mag was converted to a distributor.
You need to have No1 piston to TDC on the compression stroke and see where the rotor is pointing. Hal
