Re: 656 Gas died twice, 2nd time no restart
Posted by El Toro on July 16, 2007 at 03:41:16 from (205.188.116.73):
In Reply to: 656 Gas died twice, 2nd time no restart posted by TX656 on July 15, 2007 at 20:37:16:
Pull the coil wire from the distributor cap and hold it within 1/8-1/4" of good ground on the tractor while someone makes an attempt to start the tractor. If you have good hot spark from the coil wire reconnect to cap and pull off one the plug wires and check there for fire. If there's fire there at the plugs. You probably have a fuel problem. Don't be jerking parts off and replacing them until you find the problem. Hal
