Re: Placement of ignition switch and light switch on '43 H
Posted by Nat 2 on July 17, 2007 at 06:47:58 from (64.80.108.52):
In Reply to: Placement of ignition switch and light switch on '43 H posted by Wisconsin_Joe on July 17, 2007 at 06:24:23:
I believe the on-off switch (which is a PUSH-PULL type, not a toggle!!!) is installed in a hole in the bracket that holds the hydraulic rod, down near the base of the steering post. If it doesn't have hydraulics, the switch probably belongs in a plate in the same location.
In the electrical box, it should be the ammeter, light switch, and a fuse, from top to bottom IIRC.
