Re: bull pinion slop
Posted by D Slater on July 17, 2007 at 08:45:49 from (71.164.58.156):
In Reply to: Re: bull pinion slop posted by chris heinzle on July 17, 2007 at 05:47:31:
How much the splines, differential gear or case is worn inside will affect the play on inside end of bull pinion shaft. They had some play when new and its usualy not a problem unless there's a lot of play. Most well used tractors have around 1/8 inch end play or more in pinion shaft.
