Re: bull pinion slop
Posted by chris heinzle on July 17, 2007 at 05:47:31 from (164.119.246.190):
In Reply to: Re: bull pinion slop posted by Harold Hubbard on July 17, 2007 at 04:04:33:
I actually have one side completely apart already, bull gear and axle shaft out, bull pinion and cage out. I guess my question not one of disassembly but rather where the side slop was coming from. As Bob said, there are 2 bearings in the bull pinion cage. The outer one holds the pull pinion itself. The inner one doesnt hold the bull pinion, but rather it holds one end of the differential. The splines inside the differential, in turn, hold the inner end of the bull pinion. Now, if theres slop in the splines, or if the differential bevel gear can move inside the differential case, there ends up being slop in the other end of the bull pinion. Regarding when bearings are considered bad, how much 'looseness' can one live with? I have measured the side slop in some bearings, and they range from .008 to .020. Im thinking that .008 in the axle shaft bearings is fine, but .020 in the pull pinion bearings is not. Bearing slop that allows a gear to pretty much move sideways, like the bull gear, shouldnt be much of an issue, as long as the gears stay aligned (shafts stay parallel) with each other.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
