Re: 715 combine with 301 gasser -- Donor maybe?
Posted by the tractor vet on July 17, 2007 at 18:49:15 from (75.19.122.16):
In Reply to: 715 combine with 301 gasser -- Donor maybe? posted by IaGary on July 17, 2007 at 18:36:12:
Yea 806 and 856 , As for going in yea it will BUT you will have to swap out the Ft. covers and the rear plate and pan and oil pump pick up then ya will have to get seirous with the dist and carb and for all that work and messen around ya might as well just stuff a kit in the 560 motor and ya ain't tryen to make something work like down below in the other thread . Them Seal Power and Clevit kits are ok and not a bunch of pocket change , But the down side with them is that they are made for the A-B class holes and if ya have a block that is all A-B holes your good to go if ya got C-D holes then ya have a WEEEeee bit of a problem . Now the last time i was talken to the warehouse that i was getting my engine kits from the one gril that i delt with was tellen me that they could now get the oversized sleeves for the C-D bore class. Just had to special order them .
