Re: IH 674 Balancer timing
Posted by richardinnz on July 17, 2007 at 23:55:24 from (125.239.166.245):
In Reply to: Re: IH 674 Balancer timing posted by georgeky on July 17, 2007 at 08:34:30:
Thats right, putting #2 at TDC leves #1 at bdc, as I said, tdc or bdc don"t matter as the balancer is driven at 2 X crank speed. The reason for using #2 at tdc is because this brings the crank gear timing mark to the bottom so you can see it with the timing cover in place, you can"t with #1 at tdc. If you time with #2 at tdc, fit the balancer, then turn the engine so #1 is at tdc you will find that the balancer will come back to its original position because it is driven at 2 X engine speed.
