Hastings Piston Ring Set
Posted by Kendog on July 18, 2007 at 04:52:17 from (74.65.39.174):
The new replacement rings delivered for my A (purchased though this YT site - with outstanding service I'd like to add).
But none of the new rings are beveled or dotted - just straight cut, (one set is the 'top groove' set) and the oil ring is a simple waffle configuration. Every replacement set I've seen IS beveled or tapered with a specific assembly order.
Any issue with this straight-cut design and experience with the Hastings rings, or change in break-in procedure?
Thank you, Ken
