Re: Hastings Piston Ring Set
Posted by Janicholson on July 18, 2007 at 09:30:30 from (66.173.50.85):
In Reply to: Hastings Piston Ring Set posted by Kendog on July 18, 2007 at 04:52:17:
El Toro's idea is correct. If no response, or reaction from Hastings, I would put them on a very flat surface--plate glass-- and carefully determine if there is a cup side to them. If the outer edge has a clearance (paper thin) between the glass and the edge, it is right (top) side up. If it is flipped and that side has some clearance, that side is up. The very slight cup allows sealing on the way up, andscraping on the way down. If there is no difference, I would say either way is fine. JimN
