Re: 560 rim/wheel clamp problem
Posted by Nat 2 on July 18, 2007 at 05:26:08 from (64.80.108.52):
In Reply to: 560 rim/wheel clamp problem posted by Clefus on July 17, 2007 at 18:59:07:
Armando has it right. On all the double-bevel rims I've seen, there are four bumps on each bevel. At least one clamp should be located on one of these bumps.
