Re: Loader changeover to hyd.bucket and down pressure
Posted by Janicholson on July 18, 2007 at 14:21:36 from (66.173.50.147):
In Reply to: Loader changeover to hyd.bucket and down pressure posted by r bond on July 18, 2007 at 13:47:11:
Diagrams are in the archives, so I will give some words. A spool valve for two way cylinders(if open center system) in a diagram looks like a plus mark + the pressure goes into the in port Left projecting part of the + and goes around the spool valve and out the opposite side to the resivoir. A cylinder is placed so that the end ports of the 2way cylinder are connected to each end of the vertical part of the plus mark. As the spool is moved in the valve, it shuts off the return flow (across the valve) as it directs fluid to one of the two cylinder hoses. It also lets fluid back into the other port and from there it returns to the resivoir. If the valve is then returned to the middle, the port that was getting oil is again sealed off, as is the other port to the cylinder. the center is again open, allowing fluid to go left to right through the + valve. This holds the cylinder in that position. If the spool is moved in the opposite direction, the inlet port is connected to the other cylinder hose, and the return flow is again stopped causing the cylinder to move in the opposite direction. the fluid in the other end of the cylinder comes back (in what was a supply line and is now a return line) and goes to the outlet connection to the resivoir. More than one two way cyl;inder can be connected to work this way, just put a T at one cylinder and run a hose to the same end on the other cylinder. Do this at both ends and all is well. Good luck JimN<
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
