Re: 560 rim/wheel clamp problem
Posted by Armand Tatro on July 19, 2007 at 17:31:35 from (67.176.252.97):
In Reply to: 560 rim/wheel clamp problem posted by Clefus on July 17, 2007 at 18:59:07:
Case-I.H. dealer should stock clamps and bolts&nuts or can order them. I ordered some for an M awhile back but they are different. Also do not use lock-washers because on axel clamps or rim clamps because they can BREAK and than you have LOOSEBOLT and same problem. Just TIGHTEN with wrench and be sure to check as i suggested in last post. Armand
