Re: 1948 Farmall C
Posted by El Toro on July 20, 2007 at 07:20:50 from (64.12.116.73):
In Reply to: 1948 Farmall C posted by shane Hoefs on July 20, 2007 at 07:12:41:
You probably have a bad coil. When it quits running you need to check for fire from your coil wire by holding holding it near a good ground while someone makes an attempt to start the tractor. You need to do the ASAP. before the coil has a chance to cool. Hal
