Re: 1066 spindles
Posted by Owen Aaland on July 21, 2007 at 04:59:50 from (65.165.246.55):
In Reply to: Re: 1066 spindles posted by Hugh MacKay on July 21, 2007 at 02:30:01:
You have one more step you can do before the tapered arm kit.
Make sure the spindle bushings and thrust bearings arre in good shape. Install the arm and nut as tight as you can. Make sure you haved the arm where you want it. Weld a bead completely around the nut, welding it to the top of the spindle. Weld the bottom outside of the nut to the arm.
Your arms are already worn out along with some wear on the splindle splines. If in the future you want to go to the tapered arm kit, grind off the welds and get a new nut. There will still be enough good threads on the splindle to use a new nut.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
