Re: Bob M, I need your help
Posted by Hugh MacKay on July 22, 2007 at 05:11:53 from (209.226.247.76):
In Reply to: Bob M, I need your help posted by Paul Shuler on July 21, 2007 at 15:28:42:
Paul: On your H problem, you did say it has mag ign, right or wrong? I must admit I shy away from mag problems, having had nothing to do with them since 1955. However if it is mag ign you must have two problems, as tow starting a mag ign tractor would have nothing to do with starter, battery, generator, etc. What I do know about mags, they can be tempermental.
Aside from the mag situation, I've had much the same starting problem 3 times in the past 50 years and all with distributor ign. I've had 3 Ampmeters fail and each time the tractor stopped dead in it's tracks. No starter or no fire. The first one was Farmall 300 when it was less than two years old, stopped in the middle of the field baling hay. My 130 did the same about 10 years ago, stopped going down rows cultivating. The 140 I have had the electrical destroyed when I bought it. We did get it running with a series of jump wires, but I had to replace the ampmeter before it would start and run on it's own. I don't remember checking the lights on 300 or 130, however on my 140 the lights did work.
Just something to think about.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
