Bob M, I need your help
Posted by Paul Shuler on July 21, 2007 at 15:28:42 from (166.128.138.236):
Bob, I hooked up my lights and they work. When I turn them on the amp gauge deflects to the -. Now for some reason the tractor will not turn over. I can't even pull start it. I put all new wires in to the lights and from the fuse to the light tab on the reg. The dimmer wire was dust so I just removed it.There was a large wire going from the neg side of the ampmeter to the fuse. I didnt see it in your diagrams so I removed it and it wont turn over. So I relaced it and still wont turn over. As you can see in the photos it has a key as a kill switch. I charged the batt to full just a few nights ago and it is now dead as a hammer. Dont know if these photos will help you or not. What in the world have I done. It started and ran great till I started trying to fix the charging problems.
Paul
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
