broken off pipe on hyd pump
Posted by baler 46 on July 22, 2007 at 09:50:03 from (205.247.202.200):
Hi
Got a little problem on my farmall h the pipe that comes out of the hydraulics pump on the belly pump broke off below the casting on the belly pump.It does have a loader on it too so there was a reserve tank on top of pipe.But i need to get that piece of pipe that's left on the belly pump out of there to put a new pipe on.I can not see the pipe out of the hole,any one got any tricks on how to get that out of there? Will a internal pipe extractor get it out, do not want to lose that piece of pipe down in there.I"m think i could spot weld a pipe extractor to a socket extion and get it out with that .Think that will work? Any better ideas.
