Re: broken off pipe on hyd pump
Posted by Owen Aaland on July 22, 2007 at 10:10:30 from (198.70.47.171):
In Reply to: broken off pipe on hyd pump posted by baler 46 on July 22, 2007 at 09:50:03:
You should be able to remove the broken with an extrator.
I would not worry about welding it to a socket, that is what duct tape is for!
If the broken piece should happen to drop inside the clutch housing it will not interfer with anything there. Most likely it will be stuck on the extrator and will take some effort to remove it from the tool.
