Re: Made some more progress on my basket case H
Posted by GordoSD on July 23, 2007 at 12:26:34 from (66.115.200.140):
In Reply to: Made some more progress on my basket case H posted by neblinc on July 23, 2007 at 07:01:09:
You should try to push those pistons out the top. When water gets in the engine it goes to the cylinder and piston. Then rusts solid. Very little water ever gets between the sleeve and the block because of the press fit.
Going from the bottom out the top , most likely the sleeve will give up easily. You are going to have to take them out anyway.
Gordo
