Re: H Won't Start
Posted by neblinc on July 23, 2007 at 13:13:14 from (24.123.122.114):
In Reply to: H Won't Start posted by IndianaRed on July 23, 2007 at 12:12:31:
Was the carb rebuilt also? All it takes is a tiny bit of crud to block a passage so no fuel can get to the cylinders.
Do you have your high idle/load scew around 3 to 3 1/2 turns out from bottom for a starting point?
Everything points to the fuel system since you can get it to pop using carb cleaner in the cylinder.
Randy
