Re: Removng International 454 Final Drive
Posted by Dave in Southern IL on July 23, 2007 at 15:06:44 from (216.138.60.195):
In Reply to: Removng International 454 Final Drive posted by Bob Patrick on July 23, 2007 at 13:01:58:
I am not familiar with the 454 but I recently replaced a brake seal on my 424 and in order to accomplish that you must drain and remove the hydraulic housing, drain the differential housing and remove the bull gear which is attached to the end of the drive axle by either a bolt or a snap ring. It is not a hard job but messy and time consuming. I think that the two tractors are similar enough that you would have to follow the same procedure as I did.
