Re: H Just Popped!
Posted by El Toro on July 23, 2007 at 17:10:38 from (64.12.116.73):
In Reply to: H Just Popped! posted by IndianaRed on July 23, 2007 at 16:18:25:
I think you need to check to see if your distributor is in time again. Bring No1 piston to TDC on the compression stroke. Your notch on the damper pulley should be aligned with the pointer and both valves on No1 cylinder should be closed. Then look at the rotor to where its pointing. Your plug wires need to be in this firing order on the cap too. Hal
2-1
4-3
PS: You can have fire at all the plugs even if the distributor is timed wrong. It's just not firing in the correct order.
