Re: Made some more progress on my basket case H
Posted by John A. on July 23, 2007 at 18:48:38 from (4.89.244.1):
In Reply to: Made some more progress on my basket case H posted by neblinc on July 23, 2007 at 07:01:09:
neblinc, Try this....Take the block out of the press, get it outside, fill the #3 cylinder with diesel, add a splash of gas, set on fire, let it burn itself out, Now>>>>go press that piston out. the heat of the fire will expand the sleeve and allow the piston to be pressed out more easilly. Hope this helps.
Later,
John A.
PS if that piston is more to TDC then you may need to repeat the process 2 or 3 times. Later.
