Re: Update on 686 T/A
Posted by Owen Aaland on July 24, 2007 at 00:07:09 from (65.165.246.55):
In Reply to: Update on 686 T/A posted by Mark in C.C. on July 22, 2007 at 19:18:00:
With the clutches released you should be able to turn the TA assembly. You said that it turns easily. It should turn in one direction only. If you can turn it both ways the overrunning clutch is not holding. The disk in the TA clutch sould be able to turn both ways independent of the clutch cover/flywheel when the TA clutch is released. Another way you can check to make sure the clutch is releasing is you can turn the TA assembly, now take the block out that is holding the main clutch released. You should still be able to turn the TA assembly but now the TA clutch disk should not be turning when you turn the rest of it. If it does not turn this way then the TA clutch is not releasing. If the disk can not spin when released you will not have the slower TA speed. The most usual causes are out of adjustment, one of the pivot pins coming out of a lever, or the disk lining coming apart and wedging tight. The cast plate sometimes breaks around the lever pivot pins. A missing pivot pin can usually be replace through the hole on top. To replace the clutch you have to split the tractor at the main clucth. The TA clutch is removed through the top after removing the drie shaft through the front of the clutch housing.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
