Re: Polarize gen. (H)
Posted by Bob on July 24, 2007 at 09:39:38 from (69.178.229.154):
In Reply to: Polarize gen. (H) posted by stevex on July 24, 2007 at 09:04:44:
Your tractor left the factory (+) ground.
It will function equally well with either ground polarity, so long as the coil (assuming battery ignition) is properly connected.
Set the battery polarity up the way you want it, then polarize the generator. The procedure is the same for either (+) or (-) ground... momentarily short the "BATT" and "ARM" terminals together at the regulator.
The point of the instructions is to be SURE the battery polarity is set up the way you want it BEFORE polarizing the generator OR starting the engine.
