Re: f-12 carb
Posted by Farmall MD on July 24, 2007 at 15:22:57 from (64.12.116.73):
In Reply to: f-12 carb posted by preacher#7 on July 24, 2007 at 09:52:31:
Yeah, your fuel pump needs a rebuild, http://www.thefordsonhouse.com/p-farmall.html has fuel pump kits.
But your carb should not be empty after only sitting overnight. If your carb is empty, then your petcock is leaking. It's not possible for the fuel in the bowl to leak back down, cause the inlet is about 1-1/2" above the float level. If just sitting overnight, you should be able to fire it up and pick up prime again before it dies. Doug N
