Re: Does Stage II Have 2-Way Hydraulics? (Tell The Truth!)
Posted by CNKS on July 24, 2007 at 17:27:15 from (204.249.178.32):
In Reply to: Re: Does Stage II Have 2-Way Hydraulics? (Tell The Truth!) posted by City-Boy McCoy on July 24, 2007 at 16:38:50:
To clarify my answer above (you already know this). Fast hitch or 3 point weren't available when IH used that valve, so it was for trailing implements, which do have down pressure -- I was thinking about the one way Saginaw 3 point on my Stage 2 Super H, which would probably work better with some type of depth control system. But, my understanding is the down pressure on the Super C fast hitch, etc worked quite well -- I don't have one of those.
