Re: Last piston is finally out!
Posted by Jim J on July 25, 2007 at 20:07:10 from (66.168.140.100):
In Reply to: Last piston is finally out! posted by neblinc on July 25, 2007 at 06:12:23:
On the H & M you can drive the piston & sleeve out the bottom. When I ran the salvage yard I had an axle shaft out of a truck and would use it to drive the stuck pistons out the bottom of the bore of H & M blocks.
