656 diesel charging system
Posted by CharlesS on July 26, 2007 at 08:53:34 from (4.90.192.215):
Last fall my 656 hydrostat diesel quit charging steadily. Sometimes tellite would to out at higher rpm. Had the local alternator man check out alternator and it is okay. Changed regulator and still had intermittent charging at high rpms but better than before the change. Put two new batteries in this spring(others lasted 10 years) (Yeah I know that is unusual) Cleaned grounding terminal on alternator/regulator terminal and now charges at or above 1300 rpm consistently. Also charges at 700 rpm. Does not charge from 800-1200rpm. Don't know where else to look. Pulled the 4 connector plug at the regulator and cleaned but no change in charging status. Checked continuity from alternator to regulator on all wires ok. Any suggestion?
